DPStewart
OK...I'm experiencing a weird...can you help? Here it is:
I have an hour tape recorded at 24P using the STOCK DEFAULT scene 5 setting.
(24P is the default in scene 5 not 24PA)
I am capturing it into Adobe Premier Pro CS3 using Premier's 24P/24PA setting.
I have used this scene 5 default before and captured into P.Pro CS3 several times before and the playback is fluid and gorgeous.
PROBLEM: This time, at the 20 minute mark, when I turned the camera off and had a break before the next talent arrived, the capture goes wonky (technical term).
Everything after this 20 minute mark has HUGE AWFUL JAGGIES of a type so bad I am assuming I am looking at the pull-down frames or something. But it's not at a regular interval - mostly during any motion.
So, I captured this bad portion using the P.Pro standard DV 30 frame setting and it seems to look just fine.
Any ideas on what may have happened here?
~Thanks!
~Thanks!
