Looks good. I think you forgot to deinterlace your quicktime file. you can see the jaggy lines during movement in vimeo. You can probably just open the quicktime file and hit command-j, go to video source and check the deinterlace box on the bottom right corner. Then replace your footage in vimeo..
exactly what i was thinkingLooks good. I think you forgot to deinterlace your quicktime file. you can see the jaggy lines during movement in vimeo. You can probably just open the quicktime file and hit command-j, go to video source and check the deinterlace box on the bottom right corner. Then replace your footage in vimeo..
nice work.
personally i dislike the abrupt affect of a camera flash in the middle of my footage.
[goes back to when a fantastic shot was ruined by an overeager photog]
unless you were looking for that, it's easy to fix.
cut to the last frame of the shot just before the flash.
then adjust the sequence duration to fit the open slot- by whatever factor makes it fit.
So, there's a little slo-mo in place of the flash thing.
looked very nice. liked the wide shot of the church from the back- just like being there!
short though.
most folks like hour long things showing all the festivities and stuff.
[shot one wedding, will never do it again- but the food was good.]
