Water housing for fs700
cckid
Hello,
Soon I will be investing into a waterhousing for the new fs700. Has anyone tried any of the existing waterhousings on the market.
If you did please send some links, first hand experiences and recommendations...thanks
Hello,
yes I am looking something like that...did you tested it? it seems to me the model on the link you attached is for the sony fs100...does anyone know are they gonna release a ewa marine sony fs700 model also? and if yes, when is this coming out?
Looks compatible with both...and no, I haven't tested it but it seems nice for the price if you don't have the full money for a real water housing.
Errg - those things are pretty horrid
Id consider a cheap vid cam with a hard housing
You really gotta think through using one of those things, but then maybe you can do that thinking/testing
There is interesting potential with the FS series with AFocus, ISO performance and the like
I mean using a bag like that changing the aperture for example can be hard, it sounds simple until you are dealing with a million other issues of sustaining your life in the water, composing, communicating with talent - whatever - of course maybe you are already an expert at that stuff
It such a shame to blow everything on not being able to get at a button..
S
I've owned many housings over the years.
How much money are you willing to spend?
Do you want a flat or dome port?
How deep do you want to go?
The Ewa is one of the most difficult to use...
When the water pressure was too great, the on/off button stopped working.
A fine example of the reality of such a device.
And also an example of the 'thought process involved'
The FS with an FMU - you roll before you get in, but that is tricky because you cant change WB and stuff while you are rolling
So you go down, test WB, surface, adjust, repeat, repeat, roll, shoot
Its doable.. but a total pain
S
Info from ewa-marine on the FS700.:
We have had the camera in house and have made a sample housing. We will be rolling out a series of housings for the FS700 in week 36 / 37.
The housing for the FS700 will be called VFS7.
Info on the FS100 version:
The VFS1 standard housing can be used with lenses up to 72mm filter thread, where as the adapter delivered with the housing can be used with a lens with 62mm filter thread. The housing was designed for the FS100 kit and the lens delivered within. There is no particular manual for this specific housing. We are also able to make a custom housing with a larger front port for filter threads 77mm and 82mm, but this would be a special order housing.
The maximum length of lens this housing will hold is 11 - 12cm approximately.
Hello
thanks for the reply...my primary use would be swimming pools and dont see myself going deeper than 4-5meters...my main lense would be a tokina 11-16 and some zeiss cinemod zf with 80mm diameter....I will be inclined to short shooting periods...getting shots that are already pre planned...that is one of the reasons I considered ewa housing....are there any other options...if someone has any links please send those...thanks...
I thinking EWA are the market leader in that 'class' of housing
Ive never enjoyed them but they can be made to work with planning and extreme care.
