It seems that there is very little difference if not any, between that and a shotgun. I've done lots of tests. I find that with a shotgun I have to constantly reset the levels on my recorder, whenever the shotgun mic is pointed in a new direction, but with the hyper I can just set it once and it should get the job done for wherever it's pointed in that room. Is this true, or am I doing something wrong? As far as the sound goes it seems they are the same, but a shotgun is better, cause it can work at about two and half feet away, in some shots, as oppose to only two with the hyper. So is it worth it having both?
