Bart_Boge said:Mr. Cheung,
But then you should REVISE your article, because we all know that standard FW400 can handle DVCPROHD(100) streams. As Barry has said, Apple announced this a YEAR ago.
Barry_Green said:Mr. Cheung,
If you're at the booth, definitely talk to Jan Crittenden Livingston, she's the product manager for the HVX line and is the single most knowledgeable person about the HVX.
DV Rack doesn't currently support DVCPRO-HD. So if you were using the HVX with the existing version of DV Rack, DV Rack would only be able to recognize the SD signal. But if they were to update their software to understand the DVCPRO-HD codec, then you could definitely use it with the full HD stream. The camera unquestionably supports full-bandwidth streaming of all the codecs. The limitation about SD is DV Rack's limitation, not the camera's limitation.
not5150 said:I then asked about direct to harddrive recording, because I use DVRack. He said that the camcorder only does SD over the firewire connection. I should have come back to the booth to inquire more, but I had a meeting in South Hall.
That's a good indication that chemistry in Canon's labs is boiling. At least, that's what it's better be doing, or otherwise they'll quickly get behind everyone.Canon was like a morgue when I rolled through.
Dmitry Kichenko said:Canon......they'll quickly get behind everyone.
Not so sure if they are too slow. i have edited footage in DV with them. DVCPRO HD is more in Mbs, but not that much more. Who knows, we will need to experiment once this camera is out.soarprod said:Ipod is too slow for direct recording. You need a powered hdd like a external Western Digital or Segate (forget "crash" maxtor)![]()
Barry_Green said:Now, if you're talking about 720/24p, no it's not that much more, it's 40mbps vs. 25. But for streaming out the firewire port, I'm fairly certain it's going to be the full 100mbps stream at all times, so it's a *lot* more than DV. It's 4 times as much.
soarprod said:You need a powered hdd like a external Western Digital or Segate (forget "crash" maxtor)![]()
