Like you, I'm curious about those Viviana RF whip antenna savers. We all have learned from Larry of Lectrosonics that when the whip antenna rests against the talent's skin, it affects RF performance. Along comes Viviana with a solution. But I've found nothing about it's performance. It helps, but how much? They don't say.
Now you all know that I am incredibly cheap. So, I decided to test the idea. But instead of spending $18 for a piece of rubber (or whatever it is). I happen to have some silicon tubing that was just the right size. So I cut a length and put it over the antenna. I put the transmitter under a tight fitting shirt and made sure the antenna was pressed up against my skin. The results are that the RF level improved at least 8db and maybe even 10db.
I'd do a side-by-side comparison with the Viviana product, but hey, $18 for a rubber tube....... maybe one of you has one and will mail it to me and I'll do a side-by-side comparison.
That got me thinking just now, what the results would be if the tubing wall thickness was thicker, to get the antenna further away from the skin. I'll report back when I get around to testing that.
