Vimeo settings, + fps question - please look
digifruitella
http://vimeo.com/help/compression
the guidelines say that all videos should be 30fps..
I have a video that I edited in Adobe Premiere Pro, with a Sequence setting of 23.976fps... in the editor, when I render it and play it back... it plays back beautifully. Just the way I want it to.
I exported it as an MP4 file (with NATIVE fps, 23.976, I haven't tried the recommended 30fps yet) and uploaded it to Vimeo, and played it there - and I SEE that it's off.
The way my video is edited is very fast, and relies heavily in Audio/Video synchronization.
In Vimeo - I can SEE that it's off. The video is just a few milliseconds lagging. It's not catastrophical, but spending a month editing and playing it back over and over again in Premiere Pro, I pretty much know how it should play out... and the moment I saw it playback on Vimeo, I spotted this slight un-synchronization.
Is this a frame rate problem or am I exporting it wrong?
My Adobe Premiere Sequence settings are
Sequence 01
1920 x 1080
00;20;26;11, 23.976 fps
48000 Hz - Stereo
when I right click on the actual audio IN the timeline the settings are
Source Audio Format: 44100 Hz - compressed - Stereo
Project Audio Format: 44100 Hz - 32 bit floating point - Stereo
Total Duration: 00:04:39:37476
Average Data Rate: 39 KB / second
Can anyone tell me if there's something I'm doing wrong?
the 44hz, and the Sequence 48Hz are different, yes... but why is it when I play it back rendered in Premiere that it syncs perfectly then? or does the problem lie in something else?
Again for reference, my video is very experimental, the cuts are very fast that sync with the sound.
Interesting you mention that.
I do notice that when I play it in Premiere Pro when everything syncs perfectly, it's fine.
When I export it and play it back on comp, OR vimeo - it's slightly faster. I think you're on the money that it can be a pitch problem... now how do I go about getting rid of it?
And yes, another thing I want to mention!
earlier I posted th Sequence settings.
1920 x 1080
48000 Hz - Stereo
you see how t says 00:20:26:11
well, my video is actually 34 seconds long... could this be something to be concerned about... sequence saying one thing and timeline being longer by almost 14 seconds?
