vimeo compression?
shapeco
so now that i am on vimeo i would like to get my clips from adobe Premier cs3 onto there. What do i need to do to compress? I just can't seem to figure this one out.
Thanks,
john.
Hi,
I like Vimeo for its quality presentation. I assume that's what you're going for, too, an HD product viewing experience.
If so, the end product would need to have these specifications:
  • H.264 CODEC (MP4)
  • Size 1280x720 HD (640x480 SD) (Pixel Aspect Ratio 1.0)
  • 30FPS if NTSC or 25FPS if PAL or 24FPS - Vimeo converts to 24FPS
  • Keyframes ever 30 frames
  • data rate 5000kbites/sec HD (1800 kbits/sec SD
  • Audio 44.100KHz at 128kbps
  • Deinterlace
That's just from Vimeo's site.
Export using Adobe Media Encoder using these settings, pretty much as in the pictures:
and
Good luck!
well the clips loaded just fine on the page, but they look to be in a 4:3 instead of a 16:9..... did i miss something? I am guessing change the option from square pixels to 16:9....
  • Deinterlace
A PAR of 1.0 with those dimensions will get you 4:3 video. In addition, you shouldn't deinterlace material from the HVX if you shot in P, PA, or PN mode.
