DPStewart
OK, now a lot of you all already know this stuff so this goes out to folks that are less familiar:
Re-encode your videos THROUGH Vimeo.
Yup, you can use Vimeo to get BETTER small-file-size encodings than anything I have ever been able to produce with Premiere and Media Encoder. ESPECIALLY the 720p size!
Upload your video to Vimeo, and then download it at both the 1080p and 720p sizes and you'll find that the bit-rate is TINY considering how good the video will look. I have tried setting after setting after setting on Premiere and I've never found anything that can come close.
Now you have excellent quality videos that are so small in data size that you can easily include them in things like Electronic Press Kits, Portfolios, Websites, Dropboxing, heck you can even email them when short enough.
I'm talking about data rates as small as 2,500kbps with EXCELLENT quality.
Tip #2. - Rendering your videos out in DNxHD in 10-bit with 'data levels' included makes your uploads to Vimeo and YouTube videos come back even better.
Tip #3. - Vimeo allows you to select how your videos get played back for the viewers and some folks overlook this. The SETTINGS tab on your video allows you to select 1080p as the playback resolution instead of the default of 720p. Just bear in mind that is a tougher data stream for many people's internet connection to handle. But if you've ever wondered why other people's Vimeo videos seem higher-res than yours...check that out in your video's SETTINGS tab.
OK, that's all for now.
Yeah, I know most folks know this stuff...just tryin' to do my civic duty here.
~Cheers
~Cheers
