For the past year I have been trying to eliminate "noise" in the video signal from my DVX100A. There have been various posts about various amounts of noise in the video signal, with various suggestions on how to reduce or eliminate it in order to achieve the cleanest image possible. Specifically, the noise I am referring to is the 'digital snow' which appears in dark areas or mid-range colors (greys or other flat colors). Despite my best efforts, I have been unable to eliminate (or reduce to an acceptable level) the noise I get from my DVX.
First, a recap on my strategy to reduce noise. From tips from various respected members of this board over the past year or so, I have used the following guidelines when composing a shot:
- Lots of light. Wherever possible, more light is used to properly illuminate a shot.
- Correct white balance and black balance
- Master PED between -4 and -8
- Lowered Detail setting between -3 and -5
- Gamma curve "Black Press"
- Coring raised to reduce noise
- Chroma level down
Despite all of this, I still get noise. I am beginning to think there is something wrong with my camera. I know that the image looks 'good' overall, however I still see noise in certain areas of almost every shot.
Here is the result of a small experiment. The following is a 6 second shot of a car across the street from my house, which follows the guidelines listed above. f2.8, 24PA, zoomed all the way in, on an overcast day (so there is an even spread of daylight all around). I did not record this to tape -- I went straight to my laptop over firewire and capture the clip in final cut pro. Here is the original raw DV file, with no modifications or filters, which is 18MB. Please go easy on my server, and download this clip locally and do not stream it:
http://mosey.org/film/2007/noise/car.dv
Here is a smaller version (4MB) of the very same clip which has been encoded with h264 using a compression setting that faithfully reproduces the original DV file pretty closely (iow, the noise is retained):
http://mosey.org/film/2007/noise/car-14-x264-aac.mp4
When you look at this clip (especially at full screen), you will notice noise in the upper left of the frame, in the area of the green door. You will also notice noise along the bottom of the frame along the entire bottom of the grey car. With the above settings in place I should be able to turn on my camera and capture footage that is clean and crisp and ready for editing. Instead, I am constantly plagued by noise, which makes its way into my editor and spoils (IMO) a good deal of my footage.
OK. So here are my questions, and requests for help.
- Do you see the noise? Am I crazy and there is really nothing out of the ordinary? I have seen many other clips of DVX footage that look fantastic, and have no noise at all. Why do I get noise?
- Do my settings listed above ensure a noise-free image? If not, what should I try next?
- Could there be something physically wrong with my camera? If so, what do I do about it?
- Is someone willing to go outside their residence and film a neutral-colored car in their neighborhood in such a way as to contain absolutely no noise? I want to be reassured that it -can- be done, and which settings were used to achieve it. I have ftp space available -- please PM me and I will send you upload instructions for your 6-second raw DV clip.
I hope the root cause of the noise I get in the DVX100A will be found, so I can eliminate it altogether.
Thanks for helping.
db
Update: I've added a screenshot indicating the areas of noise, which are visible when the clip is playing:
http://mosey.org/film/2007/noise/car-14-x264-aac.png
- Chroma level down
Thanks for helping.
db
