Hi All,
Quick question for external recorder users, specifically Ninja and other HDMI devices.
Can the device record picture and sound while recording variable frame rates in the camera? I know it won't record at the variable frame rate, but I'm thinking the camera must still put something out of the HDMI port for monitoring purposes (which is why they kindly added the "no audio" warning for us in the firmware update!)
I'd like to make more extensive use of off-speed recording, but as everything we do uses location sound, that is an issue for me. At present I get sound while I am recording off speed by using a second camera, and visually synching via the clapperboard. Doing it with an external sound recorder is a logistics headache (no common reference to tie in the audio to the appropriate video clip so a huge job to manually figure out and match up all the takes). And since I only have one AF100 at the moment, it means setting up an HVX200 which I am going to use ONLY for sound on the off-speed shots, which is a flog.
I was thinking that a fringe benefit of having an external recorder might be the ability to record in-sync sound and picture at 25 fps while recording variable frame rate internally, giving me a reference on-frame-rate pass of the footage with both sound and video to make it easy to match footage in the editor at a glance.
Anyone got any experience of doing this? Does it work even a little bit? I believe it will only work with HDMI as SDI is disabled when recording VFR, right?
Cheers, Hywel.
Cheers, Hywel.
