Vertical stretching
Austinv
http://www.vimeo.com/1300269
My squeeze mode footage looks vertically strecthed. I edit in Premiere Pro CS3 and I exported it as 16:9 and edited in a 16:9 timeline, I can not figure it out.
It is probably the most obvious thing!
It looks like it's squeezed horizontally by about 16%. What were your exact export/render settings? (Exact.)
File - export - adobe media encoder this opens up a new window.
File Format is H.264
in the video tab I set the frame rate to 23.967 (24p)
Field order - none
Pixel Aspect Ratio - 16:9 (I shoot squeeze) this all depends on your settings.
Profile - Main
Level - 3.1
Bitrate Encoding - 1 pass
Target Bitrate - 3
Max " " - 6
Quicktime is somewhat notorious for making things too narrow (as you see). Try a custom size -- 873x480 -- pixel aspect ratio 1.000 or square.
I have tried a lot of things and still have not figured this out. Does anyone else know how to fix it.
