Vertical Green lines with bright objects
max123
Hello all,
I 've got a brand new DVX100b here and I have the following problem: As soon as I shoot a bright object on the edge of the screen, I get green lines as I output to a TV monitor.
If I grab the footage, via DV, it looks fine on the CRT, but as soon as I output it to a TV (or burn a DVD and play it back) I get those vertical green lines. I tried it on 5 different monitors, same thing.
The live output from the camera does the same thing. I took a picture of the TV and circled the lines in RED. The bright object (a lamp in that case) wasn't overexposed. If the same bright object is shot dead center, no green lines! then I pan a little to put that same object on the edge of the frame... Green lines.
Any Ideas? Is this a design flaw or just a defective camera?
Karle-Philip Zamor
(paste the ftp links in your browser if the pictures does not appear)
ftp://greenpics:greenpics@declub.no-ip.org/Greenlines1.jpg
ftp://greenpics:greenpics@declub.no-ip.org/Greenlines2.jpg
