rob norton
I recently shot an architecture project and wanted the camera tilted completely up (90 degrees), while moving vertically. I only had access to a compact jib and was disappointed by how much fore/aft travel there was from the arc of the jib. I know plenty of people have used jibs for seemingly vertical moves in the past etc. but this is special application territory, where it'd be great to have only vertical movement.
Is the towercam the only product of its kind? https://www.hotheads.tv/towercam_xl.php#
Repurposed/outside the box thinking welcomed, to sum up:
- perfectly straight vertical line. I'd give up the ability to go from low to high if it means much more basic tech that doesn't need to fight gravity, essentially a slow-ish fall would work.
- a vertical slider won't work because the track will be in shot. I don't even want to think about what a vertical slider with offset arm/counterweight would look like!
- 6 feet of travel - this distance based on the 7 feet of travel from the jib, which I've always been happy with.
- lightweight canon c200 package (under 7kg/15lbs).
A drone with the camera above the propellors would be perfect for this. I've seen drone mods which change camera positions under the aircraft or attach different cameras, but I'm not sure if I've seen a camera on the completely opposite side of where it normally is. Even a very lengthy, single riser air cushioned stand would work but I don't think the product exists because it would make for an awful actual light/whatever stand.
