GH2 Version increment number on GH2
rc444
Question: if you are hacking the GH2 for the second time, do you change the version increment number to 02 and then export as GH2__V13.bin? Is this right?
If the above is correct, if you are hacking the GH2 for the 3rd time, is the next version increment number 03 and the export file as GH2__V14.bin?
Cheers
rc444
There is no need to alter the Version Increment number in PTool. Just leave it checked and the hack will work as intended.
You can set the last two digits in the patched firmware filename to any number you choose, from 00 - 99. Since the original Panasonic firmware filename is GH2__V11.bin, you'll probably want to avoid overwriting it by choosing any number except "11".
