This is a lightly used VariZoom DV Media Rig in excellent shape, for less than 50% of cost! It is very clean, and I have a couple of extra parts (the washer-compression washers which are the only things that wear). This camera stabilizer is designed Mini-DV camcorders or DSLRS weighing up to 7.0 lbs (3.2 kg). It has three basic parts: the support pod (which carries and controls the camera), the abdominal support with spring loaded suspension pod (which bears most of the weight), and the shoulder arch with counterweight, which provides balance and stability. As a system, the DV Media Rig enables longer shooting periods, more fluid moves, and give your lightweight camcorder the inertial look of larger, heavier cameras. It can also hold an LCD monitor and/or microphone(s).
Features:
Adjustable sliding top stage for uneven payloads
Comfortable abdominal support and spring-loaded suspension pod free hands to orient camera
Dual camera control handles for precise, steady guidance
Counter-weighted shoulder arch for balance and stability
This unit sells new for about $570.00 new (B&H).
Cash sale in Portland area only. Call 503.484.7713 <iamdorian@mac.com> (ask for Dorian)
Features:
