Varicam PAL? and Final Cut Pro workflow
ONE MORE FRAME
Hi, everybody?
Has anyone worked with footage of the Varicam at 25fps in Final Cut Pro 5 via firewire? Is that possible?
There isn´t any preset of 25p in any format (1080 or 720) and no preset of some Pal compatible frame rate at 720 (25p or 50i)
I read that the AJ-HD1200A can make frame rate conversion and upconversion from 720 to 1080. Is this the only solution to capture via firewire to Final Cut: make a conversion from the Varicam footage to 1080 50i?
