VaricamLT: VariCam LT Software (Firmware) Update Data
KING.Q
Carbonite Member
Ver 21.13-00-0.00
Chinese is added to the MENU languages.
New Features
1. Improvement in AUDIO UI
Direct Volume Control function added
Level Meter Display function added
2. Support for ProRes Recording in Interlaced Mode
When FREQ = 59.94i / 50i is set, recording is possible using MAIN CODEC = ProRes422 HQ.
3. Support for AVC-Intra100p
Using MAIN CODEC = AVC-Intra100, recording is possible with FREQ = 59.94p / 50p / 29.97p / 25p / 23.98p and MAIN PIXEL = 1920x1080 / 1920x1080 CROP.
At the same time, recording on F series P2 memory card is possible in spite of VFR = ON (with any setting value for fps) when MAIN PIXEL = 1920x1080 is set.
4. Additional Lens Compatible with EF Lens Mount
http://pro-av.panasonic.net/en/varicam/lt/ef_lenses.html
5. Additional Function to store CDL / LUT on SD Card
6. Additional function to beep when operating REC button
7. SURROUND VIEW function added to VF
A menu item is added to display the outside of effective area on the viewfinder screen. (SURROUND VIEW is also displayed on the VIEW screen of control panel.)
8. Support for Proxy AVC-LongG6 24.00p recording
Improvement
• Improvement to VariCam-LOOK Color Reproduction
Gamma Curve [V-452080] and setting values of LINEAR MATRIX will be changed by this update.
