Jiggityjiggs
So I just got the HVX and I've been playing around with it for the last day. I'm really excited to test out the variable frame rates in 720p mode, but also confused about the post production workflow. I've got the capturing down but don't know how to work with them in FCP.
Coming from shooting 16mm, if you over crank or undercrank, when you play back at in a projector at 24 FPS you will get the desired change in speed depending on your recording frame rate....simple enough.
However, when I shoot something at either 60 or 12 and drop it into a 24 frame FCP time line, it retains the capture speed?!?
Now am I doing something wrong? If I adjust the speed to 50% on a clip that was captured at 60fps, will FCP acknowledge that there are excess frames and still give me a smooth, clean image? or do I need to change timeline settings or import preferences?
