Hello All,
I spoke with a person at Singh-Ray about the Vari-ND and it turns out that it can not be used with anything below a 24mm lens. I was hoping to use it with the Kit lens but I wonder what is the point of having this expensive item I can not use it between 14mm and 24mm? Also, the Vari-ND can not be used with the 20mm panasonic lens which arrives in a few days.
I am totally new to using an ND filter. Can you tell me what ND filters and what size filters you are using with the kit lens and the Panasonic 20mm 1.7 lens so that there is no vignetting? Should I get a larger filter and a step-up ring so I can use some filters on both lenses?
Thanks.
Thanks.
