g.l
| We all know that variable Neutral Density filters (FaderND etc) are made up of two polarizers. But I was shocked to find that many (all?) commercial ones also act like normal polarizers, filtering out polarized skylight and reflections! In this video, I'm rotating a 7dayshop Variable ND filter - the entire filter, not just the front element. It removes the water reflections just like a normal polarizer! You can try this simple test (post your results): - hold the fader up to an LCD screen (must be LCD) - rotate the whole thing - if it gradually blocks out the LCD screen, your filter acts like a normal polarizer! It sucks! You probably don't want a fader to filter out reflections - even if you do, you can't adjust the filter angle (like with a normal pola) - once it's mounted you can't rotate it! Worse, as you fade the image, you are actually changing the pola filter angle! It sucks even harder for 3D shooting with 2 bodies - each fader usually screws on in a different rotation, so you may get different pola filtering on the sky & reflections! Why does it happen? Faders are made from two polarizers. If they are made using two circular polarizers - the problem goes away! (see tech details below). Instead it seems that most (all?) commercial faders are made with a circular at the back (for camera metering compatibility), and a linear at the front - the linear is causing the problem. Details Linear polarizers filter out polarized light, and change how they do it as you rotate them. Two linear layers do the actual fading. A Circular polarizer is made up of a linear layer, and a quarter-wave retarder layer. The retarder effectively unpolarizes polarized light - this is needed because some cameras' metering cannot cope with polarized light. So with a standard CPL, a linear layer is at the front and does the work, and the retarder at the back makes the filtered light unpolarized again. So a fader made with two circular filters (facing each other so the linear layers are on the inside) does not act like a pola filter - incoming light is unpolarized by the 1st retarder, then the two linears fade the image, then the last retarder unpolarizes it again. I've tested this and it works as it should. So, does anyone have a commercial fader that doesn't act like a pola filter?? Or can you recommend cheap CPL filters for a DIY fader that works without colour shifts or other issues? |
