This was shot on my new Panasonic GH2 with a DIY Vari ND (CPL + LPL):
http://vimeo.com/20280284
Lumix 20mm 1.7
f1.7
1/50th shutter
1080 - 24p
iso 160.
Hoya 77mm L-PL on top of a Marumi DHG Super Circular
(The Marumi got top ratings, up right next to B+W)
I read about this option for an inexpensive Vari ND solution that would also provide polarizing effects, thus giving me a Singh Ray Vari ND DUO at 1/3 the cost (i didn't splurge for the warming PL, so i just get basic polarizing in addition to Vari ND, but without the warming...).
This setup cost me about $130, instead of over $350 for the Singh Ray (again though, i don't have the "warming"...). Not having a standard Vari ND filter to compare to, my question is:
1. How much Variable ND filtration am i getting compared to a standard quality Variable ND filter?
2. You can see that as i dial in the filtration, after a certain point dark edges begin t appear where the filtration is no longer done evenly across the filter. Is this same effect experienced with a standard Vari ND filter?
Do these artifacts that begin to appear towards the darkest end of the filtration range represent the limitation of my DIY setup, or is it a standard phenomenon and i am really not supposed to filter to that degree?
Keep in mind, this is a very bright, sunny day, wide open at f1.7, 50th and iso 160. Normal exposure at that ISO is f4.5 + 4000th / sec.
Am I expecting too much from this setup or do the artifacts that appear simply indicate the limitation of the ND abilities, and i just need to back off a bit and stop down to f2.8?
Any info or comments would be appreciated.
thanks.
Lumix 20mm 1.7
f1.7
1/50th shutter
1080 - 24p
iso 160.
thanks.
