dustylense
Guys, check out the thread I just posted and give it a shot.
For sure.I'd also like to apologize for my behavior. Like a lot of you I started out shooting 16mm and 35mm and then 3CCD cams and finally on to large sensor cams, and with each change we had to not look at the camera as a tool, and not lose our minds when this tool that's suppose to make things better or easier, refuses to operate the way we're used to working, but to figure out the limitations and adjust accordingly. V-log will require that we adapt, if we want to use it. It doesn't expose or grade the way were used to, so there will be quite a number of growing pains.
I have a temper. I'll try to reign it in. Yes, I'm an asshole, but the goal here is to get and keep everybody up to speed.
I'd also like to apologize for my behavior. Like a lot of you I started out shooting 16mm and 35mm and then 3CCD cams and finally on to large sensor cams, and with each change we had to look at the camera as a tool, and not lose our minds when this tool that's suppose to make things better or easier, refuses to operate the way we're used to working, but to figure out the limitations and adjust accordingly. V-log will require that we adapt, if we want to use it. It doesn't expose or grade the way were used to, so there will be quite a number of growing pains.
Natural (-5,0,0,-2,1 SHADOW +2, HIGHLIGHT -2)
http://blog.josephmoore.name/wp-content/uploads/2015/09/emma_portrait_1080.png
V-LOG L > VLOG709 LUT
http://blog.josephmoore.name/wp-content/uploads/2015/09/emma_vlog709_1080.png
V-LOG L > Art Adams 709 LUT
http://blog.josephmoore.name/wp-content/uploads/2015/09/emma_aa709_1080.png
(Uncompressed links below each thumbnail)
Notice the sampling error on the beige wall.
In many regards, but the color accuracy of V-LOG L is not to be denied. Except for the nasty encoding error, the color is dead on. I think the ultimate for the GH4 would be for someone really skilled in LUT creation to create a low contrast Natural LUT that corrected it's color errors. That may be as good as this camera can get unless Panasonic radically improved the video pipeline, which is not bloody likely.Yeah the magenta issue is behind the vase, but it is just not that prominent in Natural and honestly I will say Natural is the best profile for this camera.
I leave you kids alone for 5 minutes and you're already fighting over your toys and picking on the new kid. If there's gonna be another pissing contest put me down for a hundred on Shian. I use his LUTs and they're dope, much more sensical way of grading. Just imagine Shian's an Australian living in a USian body and you should get along fine.
haha, s'all good. Although maybe as a CG user you can try applying the new LUTs to V-log footage and post results, cuz I'm pretty sure everyone thinks I'm fudging the results to try to sell them on the value of CG.
I'm curious, why is PORTRAIT your favorite profile?Good stuff Joe.
You've motivated me to try to dial in exact colour for my own favourite profile, Portrait, and create a LUT to apply. I'm having good luck with dynamic range so far and the chroma smearing is essentially negligible (all internal 8 bit recording as I don't have an external recorder):
