ux180 firmware v1.11 out
What areas of the cameras system are effected by the update?
Ver. 1.11-
Improvements
1. On rare occasions, the operation of REC button on the unit or a wired remote control may no longer have any effect. This problem is fixed.
2. If the card is ejected from the main slot during the simultaneous recording, the recording in the sub-slot stops 10 hours after the start of recording. The indication shows the same as during recording, and the operations of REC button are refused. This problem is fixed.
3. LCD may not show anything when the camera is booted up. This problem is fixed.
4. A very few SD cards may have a write error. This problem is fixed.
5. If the network address is changed when WIRELESS SETUP is set to [DIRECT] and DHCP is set to [SERVER], it sometimes made the camera impossible to connect to the iPad. This problem is fixed.
Only on "AG-UX180PJ"
• The quality of image in PM mode is changed to place importance on the resolution.
Has any of the firmware updates corrected the timedate issue of no burn in SD mode? My understanding is that when in SD it won't burn it in to the image. (for us deposition videographers)
