Uv Filter ??
I need the best "bang for the buck" 82mm UV filter for my 200. B+H has so many. DVCPRO HD is shot mostly on this camera.
Matt
Don't put cheap glass in front of a good lens. If you don't need lens protection, go without a filter, but otherwise spend the extra bucks to get a B+W filter or something of similar quality.
I've had good luck with the Filter Connection, they have most B+W filter sizes in stock, and their prices and service are excellent.
the tiffen haze 1 is reported to knock out more stops of UV light than any of the others, it's the only one I'll use.
The best that I have found if you just want a protector is the Formatt clear optical flat:
http://www.spec-comm.com/store/index.php?main_page=product_info&products_id=506
Please make sure you use the drop down menu to select 82mm round.
It's perfectly clear, no UV filtration or anything. Looks GREAT!
Best regards,
Andrew Hoffman
Senior Operations Manager
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858
301-790-0103
Fax: 301-790-0173
andrewh@spec-comm.com
www.spec-comm.com
Please visit our new online store at ( http://www.spec-comm.com/store ). New products being added daily!
