Using V-mount battery to power Led Lights like Yongnuo YN600 8volts 5amp DC input?
analogs
I have a V-mount Plate that has an 8v out, but I think the amps on those plates are 2amps.
The V-mount battery I have is a 198Wh/13400mAh.
Is it possible to get a D-tap to 8v DC cable that can handle 5 amps for my led lights or are most of these cables usually for 2 amps use?
Any recommendations on how I can use the V-mount battery to power these types of portable led lights that usually require 8 volts at much higher amperage greater than 2 amps?
I was considering using Dtap to Npf adaptors cables but the light requires 2 Npf batteries which will just add too much cabling and adaptors for my use.
Thank you.
The watt/hr spec does not indicate an ability to deliver amps .. or that wattage for an hour
Many voltage converters on Amazon eBay if you can make or get cables made
Over the years for oddball power supply requirements, I've used "Buck" converters. Just mount them in a Jiffy box which you can buy from most electrical hobby stores. This will protect the Buck converter unit. An alloy Jiffy box would be best as it will act as a heat sink. Voltage conversion at higher amperage will generate a bit of heat. A Buck like the one listed below would do what you require. Using these types of units I just go straight from the D-Tap on the V-Mount battery. A Buck converter will auto-range on input so as your V-Mount drops voltage the output voltage and current will remain constant at whatever levels you have set the output to. Output voltage adjustment is via press buttons. Set it to 8 Volts and it will deliver 5 Amps if that's what the draw is. Just a minor amount of simple in/out cabling is involved at the terminal clamps. As I said stick it all into a Jiffy box and it's all pretty well protected. I've built small neat camera and lighting power supplies using these sorts of converters.
Chris Young
https://www.ebay.com.au/itm/16393106...oAAOSwX-ZdwROg
The features:
DC-DC 8-60V intTo 3-32V 7A out. Adjustable Step-down Power Supply Digital Buck Module
Features:
With a transparent acrylic shell, easy to read while protecting the module
Using an LCD display screen, Voltage and Current can be displayed simultaneously
Using button adjustable voltage, left button to reduce the voltage, the right button to increase voltage. Press the button one time can adjust the voltage in 0.04V steps, press and hold more than 1 second to quickly adjust the voltage.
Can withstand 100,000 presses; Compared with similar potentiometer voltage regulation more convenient and fast.
Only can be used as a step-down converter, and input voltage should be >1V higher than output.
Specifications:
Input Voltage: DC 8V~60V (Recommended within 55V, the Input voltage must be higher than the output voltage 1V above)
Output Voltage: DC 3V~32V Continuously adjustable (It can save the last set voltage automatically)
Output Current: Max 7A (Recommended use within 5A, Please pay attention to heat dissipation.)
Accuracy: 1%, the voltage three bits display, the current two bits display, the unit is "A".
Input Anti-reverse Protection: Yes
Short Circuit Protection: Yes
Conversion Efficiency: Max up to 95%
Load Regulation S(I): ≤0.8%
Voltage Regulation S(U): ≤0.8%
Size: 62 x 44 x 18mm / 2.59 x 1.73 x 0.7in
Weight: 67g
Buck converter 02.jpg - Click image for larger version  Name:	Buck converter 02.jpg Views:	0 Size:	70.7 KB ID:	5682333
There's also plates like this one available:
https://www.bhphotovideo.com/c/product/1643739-REG/smallrig_3202_v_mount_battery_adapter_plate.html
I had a Tilta plate similar to this that I've use with my FS7 - and it was great to power camera, small monitor, and wireless transmitter all with one v-mount. Think I also used it a few times for follow focus motor. Just ordered the small rig as my Tilta has a bit of play with some of my v mount batts - which suddenly means a tap or bump of battery shuts down everything - which could have been disastrous - but thankfully only happened once - while setting up.
