Dan_The_Man
Hi there,
I am trying to edit footage from a Canon 7D and JVC in the same timeline. The 7D is encoded with h.264 and the JVC is XDCAM I think (this is the compressor that FCP is using when I look in the sequence settings menu).
If I import the footage and get FCP to adapt the settings to match the 7D footage then when I import the JVC footage it is unrendered'. Similarly, if I use the JVC settings then the 7D footage comes up as 'unrendered'. If I have footage from both cameras side by side on the timeline and I select h.264 compression in the project settings then the 7D footage can be viewed but the JVC remains unrendered and visa virsa.
How can I get both bits of footage in the timeline where neither need to be rendered. How can I use two different compressions in the same timeline?
Thanks!
Thanks!
