gutterball321
I have worked with SD until now and have just burned all my dvds with iDVD. I am doing a couple weddings for friends and just started using a GH2. If I export the video full quality it will be over 30gigs and wont fit on a dvd. I have been shown how to use compressor to compress the video with the DVD settings, but this gives you 2 files which I dont think works in iDVD. So is there a compressor setting that will give me good quality video I can use for iDVD?
I trid to research and this info was shown in the FAQ:
DVD-Video disc:
DVD operates on the Mpeg-2 video standard, and either PCM or Dolby Digital (AC-3) standard. To make the best use out of the disc's space you'll want to do a 2-pass Mpeg-2 video encode, and use Dolby Digital for the audio.
Quick settings:
---Should I download and use HCenc? Should I use one of the Mpeg-2 streaming options in compressor?
Thanks for the help guys!
DVD-Video disc:
Quick settings:
- Highest Quality: 2-pass VBR Video low 1.5mbps, video avg 7mbps, video peak 9.0 mbps, Audio Dolby Digital at 384kbps. This will yield about 1.2 hours on a single layer DVD.
- If you are encoding DV material, set your fields to Lower (or Odd).
- Always keep the source framerate. 23.976 is 24P, 29.976 is DV standard. (see "what framerate do I use?" section)
