hopkins802
Hi all,
I've been wanting to try this method for awhile, but just haven't had the time to tinker with settings. Is anyone here using Handbrake to break out a master ProRes export into high res H.264 files? I have my own method of cranking out a high res H.264 from Adobe Encoder by using Max Render quality (helps with scaling done within the project), as well as a color adjustment LUT built right into the export to bring back some saturation and contrast lost when encoding to H.264. I still want to compare it with using Handbrake and ProRes master files.
What would you recommend for H.264 settings in Handbrake? There are a lot more to choose from than I was expecting.
Thanks,
Dan
Thanks,
Dan
