.Using DVX as deck w/handheld mic
  • Start date Start date
G
Guest
Guest
Am trying to do a series of video segments using a Viosport H20 "helmet cam" and my DVX100 as a deck.
Want to use a handheld microphone to do on-street interviews. Tried a Shure SM57 but I can't get an audio signal. Can't input to XLR because it's in VCR mode, so am using an XLR-RCA adapter into the RCA audio in jacks.
Using the Viosport's built-in (crappy) mic works, but I need to input a hand mic. Do I need a different mic? One w/phantom power?
Hellllp! Under deadline pressure and need to solve this ASAP.
thanks,
scottso
http://www.scottso.net
Re: .Using DVX as deck w/handheld mic
hey I did the same thing and found out the same problems. What you need to do is either use a small field mixer or a mic preamp.
All in all though, I ended up using one of those digital voice recorders, they have a mic in that accepts most mics, and as long as you dont get the real cheap ones they sound pretty good. You can also use a minidisc recorder, but that adds up.
Jared -
Any suggestions as to item/brand/cost?
I need to fix this problem ASAP.
thx,
s
Actually, since I want to record synch audio to video, I meant a mic pre-amp or mixer that's reasonably priced.
Any suggestions?
thx,
s
Ok, finally found a solution that works:
Bought a battery-powered mixer (Behringer Eurorack MXB1002), hooked up a Audio Technica mic, fit everything into a backpack, wore the Viosport strapped to a Night-Ize headband (fitted for maglights) and boom - went out and did on-street interviews.
Only problem is my backpack might be a bit too small but hey at least I got the shots I needed.
thanks for your help!
-scottso
