[h=1]Olympus Zuiko Digital ED 35-100mm F2.0 Lens - $1999[/h]This is a lightly used lens and well taken care of. That being said, the lens cap is broken and the hood has gone missing. Plastic snapped on one of the lens cap clips. Right as rain otherwise. Not hard to replace. 77mm thread size. Comes with original box and lens bag. This is a 4/3rds lens. Let me know if you need a smart 4/3 to m4/3 adapter. We have those. PM or call 512-440-1400 for more info.
"The large-aperture telephoto zoom lens (fixed F stop type), which provides F2.0* in entire zoom area. It is equivalent to 70-200mm on a 35mm camera, and covers from medium-telephoto range of natural angles to telephoto area with a compressed perspective effect. Its fast shutter-speeds and beautifully soft out-of-focus image behind the main subject are an ideal for portrait, theatrical and sports shooting under the low-light. Luxurious optical glass elements, such as, four ED lenses and one super ED lens are used to give the highest image quality with optimal resolution and contrast."
Focal Length: 35mm - 100mm ( 35mm equivalent focal length 70mm - 200mm )
Lens construction: 21 Elements in 18 Groups, including Super ED lens and 4 ED lenses
Angle of View: 34 to 12 Degree
Closest Focusing Distance: 1.4m
Maximum Image Magnification: 0.09x (35mm equivalent Maximum Image Magnification 0.18x)
Minimum Field Size: 185 x 139 mm
Number of Blades: 9 (Circular aperture diaphragm)
Maximum Aperture: f 2.0
Minimum Aperture: f 22
Filter Size: 77 mm
Dimension: Diameter 96.5 x 213.5mm
Weight: 1,650g (without Tripos Adapter / Tripod Adapter: 150g)
Tele Converter EC-14: Yes
Extension Tube EX-25: Yes
Lens Hood: LH-82
Lens Cap: LC-77 (77mm)
Lens Case: LSH-1326
Filter Size: 77 mm
Lens Hood: LH-82
Lens Case: LSH-1326
