Ben Scott
Finally I have a day to test before a big high-ish end commercial slomo shoot tomorrow and I'm testing the 240fps workflow from start to finish.
Everything looks perfectly balanced on the EVF and on the 7Q but after merging the clips and checking in preview or photoshop on the macbook I'm getting the crazy magenta issues seen below which I can't dial out
Settings were:
FS7
Cine-EI
WB - 5500k
NTSC - base fps 23.97
S&Q at 240fps
Odyssey 7Q connected via extension unit raw out to SDI 1 and with 2x 512Gb drives
4k/2k Raw to RAW (.DNG)
Camera to trigger record
Project Rate: Follows input
Normally I would mess about for a week to sort this out but while i can test all day if anyone has a solution for it I would be eternally grateful. Mitch did mention that there is currently a perfectly usable raw workflow for the FS7 and 7Q at the moment, even if the image isn't quite as flat as it shold be - if anyone can help me get in that ballpark instead of 80s Miami Vice-ing up all my shots ahead of tomorrow that would be greatly appreciated.
Thanks in advance for any suggestions,
Ben
Settings were:
FS7
Cine-EI
WB - 5500k
S&Q at 240fps
Ben
