Uploading footage to the computer
taras4444
Just a quick question and excuse my ignorance (i'm use to using mini dv tape and firewire). How can i upload footage to my pc with the sdhc cards? I know card readers built into the computer can be used but i dont own one currently. How else can i do it is there a standard usb 2.0 cable every one uses or a sdhc card usb stick thats great for uploading? I dont want to buy something rubbish so any products or links would be much appreciated..... I feel so helplessly clueless but im learning!
Yea .. you just need a SDHC card reader for your computer. Connect the reader via USB cable
and slap the SDHC card in there and it will look like a new disk drive. You can copy the contents
to a folder on your hard-drive. I recommend copying the card in its entirety (all folders) (although
you can just copy the PRIVATE folder and FCP will be happy).
jeff
Sweet thanks ill buy that lexar thing on amazon, it should be fine with both lexar and panasonic cards right? And what is this whole shot put pro software thing? Would i copy the card entirely onto the pc then do the shot put pro thing for analysing it or something? And adobe should be ok to get the footage right off the computer shouldnt it? Wow its so strange from not using mini dv tapes!
Also for back up if i got the following cable http://www.argos.co.uk/static/Product/partNumber/6763664/Trail/searchtext%3EUSB+2.0+CABLE.htm that should be able to connect the cam directly to a pc yeah? As i might buy one quick just to check something while i wait for the reader.
That will not work. You need a USB to Mini-USB cable. It looks like this:
We have the unit posted above (Lexar dual CF/SDHC reader) as we drain from both 5D's and AF100's.
It's a good unit. Unless you have a really crappy unit, the speed of transfer is dominated by the media
itself.
jeff
cheers dude for that! saved me some cash, any good brands i should buy for best data transfer?
No Problem...
Honestly, it is a USB cable. Don't over think it. As long as it connects and stays connected as long as you need it to be, it will work. Buy whatever is cheapest with the proper connectors.
