uploading a video to kickstarter
kevin baggott
Hey folks,
OK - so literally a week went down the drain trying to upload a video to kickstarter.
I tried over a hundred variations of compressions. Wrote to kickstarter "wtf?" waiting to hear back
the file max for kickstarter is 500mb.
I have fcp x from a new i mac - 10.7.4 - using compressor - and any file i make above 200mb it chokes. Ive used compressor and also fcpx just making a quik time file.
kickstarter says it like h264 and kbps to be at least 1500 or mbps to 1.5 at least - did that- i did every variation i could think of.
I uploaded the vids from my desktop as someone suggested vs from external harddrive - ng.
anyway - 200mb and below just looks like garbage.
Any suggestions - most appreciated.
Hi BenB
its a quiktime movie
4:32 in length
659.47 mb
h264 1920x1080 frame rate 23.976
of course I always shrink the file down when uploading.
all it says from kickstarter is "try another file - file ng." Nothing more then that it says. If the file is too long for instance it rejects it right away. otherwise it loads - then at last minute says ng.
What do you mean by this? You said that Kickstarter doesn't accept files over 500MB, and that the export you are happy with (not sure why it needs to be 1080, when 720p or even SD would work pretty well for the window that Kickstarter displays video in) is 659.47MB. So what are you doing to get it under 500?
correction benb - just made a quick time file from the actual final cut session and it's 428mb - so it's actually shorter then the 500mb -
ive heard that try and avoid compressor if you can - and just make the file from fcp x and drag that onto desktop and upload from there.
So far no luck again today
hey gary
yeah kickstarter max video file is 500mb.
yeah ive tried 720p
I was using the new compressor to bring that file size down.
also would shrink the file in quik time after fcp x made a file for me - ng
for some reason today when i made the file from fcpx into quik time the whole file was only 428mb
so tried to upload that from desk top - ng.
I just tried this as well - someone had figured a problem out for themselves - "I figured it out. I had to go to Tools > Add-ons, which opens up the Add-ons Manager, then I had to go to Plugins and enable Shockwave Flash 11.1.102.63. Apparently, Kickstarter uses some form of Shockwave or Flash to upload their material. The more you know!"
Not knowing exactly what settings you're doing and such, I'm going to say let's take a deep breath, relax, and perhaps simplify things. Try Methods 1, 2 and 3 here, see if they help. I have found in the past that taking the very simplified "consumer" route solved a few mysteries for me in the past. I'm not saying this will fix anything, but give it a shot and see what happens. Will take you all of ten minutes.
http://www.macprovideo.com/hub/final-cut/preparing-video-web-quicktime-compressor
Hey Ben
Really appreciate you taking the time out to figure this out - I had found the link you sent at the beginning of my journey on this whole affair and followed all the suggestions - ng.
Not sure what the hell is going on. It's not my computer or the speed - I have a new vios internet. Again other files under 200mb load anything above 225 chokes. Hoping kickstarter writes back - no word yet.
I think there is definitely something wacko about Kickstarter. Every site I've uploaded too was a piece of cake just resizing and encoding in QT 7 Player, for years. Please let us know what their tech support finds as a solution. I'd love to do a test encode and upload it to a private URL for testing, myself. Yep, has to be on Kickstarter's end. This H.264 stuff is simply not that complicated.
I've really given up - I've never had a problem uploading a vide before. kickstarter is looking into it. Will let ya know Ben - thanks for listening :)
Please do let me know what Kickstarter tech support says. Ask if they can use a QT ".mov" or prefer a QT ".m4v" file. You've got me really curious now.
well - kickstarter got back to me - they said to keep the file under 250mb and there shouldn't be a problem. But the problem is under 250mb it doesn't look so good - the video is just under 5 minutes.
They say there file limit size is 500mb - so who knows.... :(
after a week though I give up and will upload the inferior file.
Hey Ben
Final word from kickstarter was "yes the limit is 500 mb - but yer safe with 250mb."
So... I couldn't get it above 250mb - so that's what I'm going to post and put a link to another file at vimeo.
Wish this was not the case.... but - ya know how that goes.
Kev
