Upload Center Help
TimothyJinx
I have tried a few times to upload a 4MB .wmv file to the member upload center. Each time it appears to go through the entire upload process. But at the end I get a message saying I did not select a file.
Am I doing something wrong? Do I not yet have the privileges to upload files? If I do end up successfully uploading a file how do I then access it in a post?
Much thanks appreciated.
Tim
According to the "Exclusions" section at the bottom of the screen I can't upload a file of any size. What do I have to do to be able to upload? I've been around for over a year. I don't have a lot of post (less than 80). Do I need to have a particular post count?
Go to the bottom right underneath UPLOAD FILE. It should say something like this
"Individual File Max. Size : 5.81 MB
Private folder Maximum size: 10.00 MB
Allowed file types:
jpg jpeg tif gif wmv mov avi txt zip "
Yours might be different because you've been around longer, but I'm not sure.
I see all that - it is exactly the same for me. But below that and to the left there is a little box captioned "Exclusion." It indicates I can't upload a file of any size.
Allowed file types:
That's normal. It basically says that you don't have the right to upload a file of any size, meaning: larger than the authorized size limit which is, as has already been noted, 5.81 mb.
I'm sure you've already done this but just in case:
Click the <Choose File> button and locate the file on your local drive. Make sure it is of the acceptable file formats. Then click the <Upload file> button. If it does not upload correctly, then, you may want to send a PM to Jarred because it has worked successfully for me several times. I'm not aware of any minimum post limits, but I suppose it is possible.
I did go through the whole upload process. I browse and select a file. Click upload and I even get the status bar indicating the file is uploading. At the end though I get the message, "You did not select a file."
I sent Jarred a message. Hopefully he can help me out.
Click the button and locate the file on your local drive. Make sure it is of the acceptable file formats. Then click the button. If it does not upload correctly, then, you may want to send a PM to Jarred because it has worked successfully for me several times. I'm not aware of any minimum post limits, but I suppose it is possible.
