upgrading to Snow Leopard today
For a year I have been hearing that the main upgrade for FCP7 would be related to OpenCL. The rumor that has been spreading amongst many editors I work with has been that FCP7 would do background rendering using the graphics card and that we would see speed increases of up to 5x what we currently were having on top of the line Mac Pros.
With that being said, I won't upgrade to FCP7 until next week so I can't test. Also - when FCS3 was released before snow leopard and was cheaper, I assumed that meant that OpenCL capabilities would extra money later down the road. Let's hope that's not true, and maybe just maybe they're in there right now.
No huge performance boosts in FCP7 yet as far as Snow Leopard is concerned. It does feel a hair snappier, but that could be purely psychological, or just related to overall OS speed improvements. It's definitely not optimized for OpenCL and Grand Central yet. I hope they'll add it before FCP8 or whatever - otherwise I have no idea why it took them so long to put out the mostly-bugfixes FCP7.
You can put as much ram as you want in the macs but they can't assign more than 4 gig of memory to any one application. Certain applications get around this by using multiple cores. All macs and versions of mac os X are constrained by this limitation - until Snow Leopard.
Is this true of Snow Leopard in its current form? What I mean is that currently Snow Leopard starts up with a 32-bit version of the kernel. You have to hold 6 and 4 at startup to get 64-bit, but some 32-bit apps won't run.
I agree. It was strange that there was never a FCP 6.1. They jumped straight to 7 and that seems to be pretty solid. I haven't experienced any issues with FCP 7 yet at all... amazingly.
Is this true of Snow Leopard in its current form? What I mean is that currently Snow Leopard starts up with a 32-bit version of the kernel. You have to hold 6 and 4 at startup to get 64-bit ...
I haven't upgraded yet I just read a heck of a lot. But I would guess that starting up in 32bit mode would mean you still have 4gig ram limits per application. I'm very keen to upgrade tho but haven't had time.
... but some 32-bit apps won't run.
I guessed as much – it will take a while for apps to switch over. CS4 Photoshop should be 64bit compatible – maybe try that one in the 64bit mode that you mention and let us know? If you do – run the activity monitor and watch the ram allocations - max it out with huge files or something and try and pop the 4 gig ram limit.
Running Snow Leopard in 64 bit is as big a change, maybe almost as big as the OS9 to OSX switch. I also remember reading something about the block checksums within files – child checking parent as well as parent checking child. Can't remember specifics and can't find the link anymore. This will be really good for all of us who are constantly copying off CF card. Less errors.
Correct me if I'm wrong but Apps optimized for 64-bit run that way in 32-bit boot..only the servers boot into 64-bit by default...or should I be booting into 64-bit to use most of my programs on my core2duo laptop which is really only running apple software (and a few adobe things.)
I upgraded my Air to SL, which has only 2GB ram, so that wouldn't really tell us much. My Mac Pro is an 8 core with 9GB RAM, but I won't be upgrading that one to SL for a while.
I believe the way it works is that 64-bit apps running on top of a 32-bit kernel will perform better than a 32-bit version of the same app, but still not to their full potential. Full potential would be realized by running a 64-bit app on top of a 64-bit kernel. It's sort of (partly) how the SL Finder is 64-bit and runs a hell of a lot faster than the Leopard Finder, even though the kernel loading by default is still 32-bit.
Anyone copy files to/from a USB drive yet? Is it me, or does it seem a LOT faster than under Leopard?
I'd upgrade the Mac Pro to Snow Leopard ASAP how freaking blazing fast would that be ;)
I wish I had one! Lol. At least I have access to them.
Even if I wanted to I can't. M-Audio doesn't have SL compatible drivers for my audio interface yet. So I'm going to wait at least until those drivers are available.
Yep, file copies in general seem to be speedier under SL (as is most everything else).
I'm still dealing with some annoyances though - Cineform NeoScene has gotten very crash-prone all of a sudden, Photoshop CS4 as well (even worse, it's usually saving a file that triggers it!). Apart from that I also have a core background process that crashes once an hour, without fail (PreferenceSyncClient).
Still mulling over potentially doing a total fresh install, I'm sure it would work out some of these bugs. Overall I'm very pleased with the speed boost, though. Now if they'd just optimize FCP7...
First time SL started up for me I would get error messages trying to open preference panels in System Preferences. It was weird, telling me they were incompatible with this version even though I did a fresh install. Restarted and the errors went away. No crashes or issues at all with anything since then. And this is my primary computer for everything but video-related stuff.
Took the dive today. Did an upgrade install of SL and everything *knock on wood* seems peachy after some basic initial testing. I'm sure I'll run into some problems when I have a little more time though. Hopefully, not during a project!
Just in case anyone was wondering...my 2007 White Macbook shutsdown in less than 2.5 seconds under Snow Leopard.
Wowza! Check out the improvements to Image Capture! You can sort by Metadata and use it to help you pick stuff off the card, etc, or just look at it :D Awesomeness. Normally there is less in the window and you'd scroll but I figured I'd show it all off.
I'm also noticing that I usually use the kit lens at either 14 or 140mm ;)
I have primes for stuff in between that! lol.
Does it really not? That sucks. I don't shoot RAW since I mostly need that card room for video.
Well Aperture doesn't, so I assume Image Capture wouldn't. I could be wrong since honestly I haven't tried it.
