Unwrap new HBR 25p GH2 mode
naavt
I apologize in advance if this is was already debated somewhere at DVXUSER but I can't find any straight answer on how to effectively unwrap the new HBR GH2 footage to use with FCP.
I find all sort of posts talking about JES and ClipWrap but does anyone can point me in the right direction to get rid of GH2 50i wrapper?
I did try ClipWrap but it seems that I'm doing something wrong because the Field continues to be set at Upper in FCP. JES really ditches one field. Is this the best solution or am I missing something?
This should work for GH2 50i Wrapper.
- Change clips field setting to none in FCP browser window
- Open a new sequence and change it's field dominance setting to none.
- Drop clips into sequence and edit.
I've read somewhere that FCP ditches resolution when this method is used. Can you conform this?
A question from my side: If I unwrap my GH2 footage (25p in 50i wrapper to ProRes 422) using ClipWrap 2.4.7, I always get those lines in the images. They look like interlacing lines, but the clips can´t be interlaced. This strange effect is visible in all players and also AE CS5. Does anybody else notice those lines? If I simply "rewrap" my .MTS files, the lines aren´t there, but then AE crashes as soon as I import the rewrapped files. Here is a picture where you can see the lines.
