Unwanted Lens Movement from Follow Focus
teayce
The equipment I am using is as follows...
5dmkII
Zeiss ZE 85mm 1.4 Lens with Zacuto ZipGear
Chrosizel DV Follow Focus
... when I focus, the torque of focusing the lens with the follow focus appears to either pull down or push up on the lens creating a vertical up-and-down movement in the frame.
I have pushed the follow focus gear tight to the lens gear and left a little space between the teeth to see if that helps - neither scenario changes the movement.
Am I missing something? This movement does not occur when I simply use my hand to focus the lens. I have used old Nikon lenses on a 35mm adapter without this issue, but these Zeiss ZE lenses are really stiff - more like a real cinema lens.
Anybody have any suggestions to eliminate this unwanted movement?
Thank you.
Troy
If your lens is shifting when you use your follow focus then it sounds like the lens mount is at fault... the stiff focusing on the Zeiss lenses doesn't help either. I have an old Nikon 85mm that is the same way.
If the lens is long enough, you can use a lens support under the lens to hold it firmly in place. I find that this helps.
Marco
