Hi!
I have two really unique custom parts made for our ARRI MMB-2 MATTEBOX.
They were made so one could use 4 1/2" round filters inside the front filter slot as well (same as in the rear slot).
If you get these, you will be using the same 4 1/2" filter tray that comes with the MMB-2 Mattebox. Simply slide it in, and it locks in there - exact same function as in the rear filter slot. The huge advantage is that - if you have the 4 1/2" + 4x5.65" mattebox version - you won't have to mix and match filters. You would be able to use only 4 1/2" filters in both slots.
Extremely easy to install: simply unscrew the four small screws holding the front shade, place the two custom parts in their place, put the shade back on and put back the screws. It takes 2-4 minutes to install and un-install the parts! See pictures for better reference.
They are made of stainless steel for maximum sturdiness. Nicely finished - you can paint them black, if you wish.
They come with ball plungers already installed (to keep the filter tray locked in place, as usual) and also 2 (two) M4 long screws, to take advantages of the holes already drilled in the MMB-2 frame (again - same as for the rear slot - but I chose blue screws instead of red). This is all you need to install them!
We made two identical sets at great cost - but we only need one set, so we are letting the other one go for a very reasonable price (compared to our total cost).
PRICE REDUCED $100 will get them both.
They are ideal for anyone owning an Arri MMB-2 mattebox. I think they won't last long - and they are unique, so once you lose them, you lose them - if you are interested, let me know fast. I posted them on dvxuser since I thought someone here will definitely need them badly.
eastco@gmail.com
George
eastco@gmail.com
George
