underwater
New_Zealand
Anyone have any ideas for an underwater gear that will work with the DSLR? I have two shots under water. They are short shots.
You will need a housing for what ever camera you are using. What is the location, depth etc. Could you shoot it with a gopro? Most housings will cost more than your dslr.
I used a Dicapac which is a bit big and ugly, but is cheap and works with any camera. I had a 5D3 in it. That's under $100. I saw another nice hard housing which had Canon 600D printed on the case. Nice looking but about $700. Unless it's a deep dive and have $1,500+ to spend, I would give the Dicapac a look
http://dicapac.com/products/products.asp?bcate=1&scate=5&menuCode=MN010500
http://www.bhphotovideo.com/c/search?Ntt=DiCAPac&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
As Michael wrote, dicapac is probably the most affordable solution if you absolutely need to make the shots with DSLRs...BUT...man...you need to have tones of patience in order to set that thing up and make it work...I tried...didnt work for me...(Im getting nervous very easy...haha) so I used my gopro!
