I already have an Odyssey 7Q+ (previously used with an A7S using a Manfrotto ball) and just ordered an FS700R, which will be here later next week. Now, I need to figure out a decent way to mount this thing to the new camera.
The caveat is that I have a Nebtek dual "Sony L" cage on the Odyssey. Currently, I don't have any cage plans for the FS700 itself. At most, it will get rails to support my larger lenses but I don't want to make it any larger then it needs to be.
You can see the cage I'm using for the Odyssey here: https://store.nebtek.com/cages/309-odyssey7-power-cage.html
To my point: the Nebtek cage has a series of screw holes on the top to undersling it (in addition to mounting holes around all other sides). It seems that the best option would be to use these screw threads to mount it to the handle of the FS700. I've spent a fair amount of time researching online for solutions, but so far all I've found is info on mounting using the stock mounting location on it or other displays... nothing underslung. I'm not fond of friction arms as I find them to be too flimsy.
Anyone know of a simple (solid) L-bracket or something that can connect these two (I prefer the monitor to be hanging on the left). I don't plan to use the FS700 on my shoulder, and the monitor also need to pivot up so I can see it while shooting low (doesn't need to pivot any other ways.)
