tom.wong
So finally buckled down and bought myself a new 17 inch macbook pro, and wanted to run some rough tests to see how practical it would be to shoot/record uncompressed on set (via hyperdeck or gemini) and encoding it with a laptop to pro res as your master files and dumping the uncompressed. This would be workflows that are lower on the budget side and can't, or don't want to deal with uncompressed. drives are cheap yada yada, but there's enough people that don't want uncompressed for most situations.
so specs are quard core, 2.3 ghz, 4 gb of ram (my ram upgrade is in the mail so i expect speeds to be faster once i pop 8 gb in there) osx 10.6.7, using adobe media encoder, because it's a full 64 bit piece of encoding software, and I find it produces better transcoding results as it bypasses mac os quicktime render engine and uses it own, leaving less issues for gamma and color shifts. (i find none at all)
obviously these won't be final results until I can get a TRUE RGB uncompressed source, this is just me playing around right now. I'll have to dig out some old hard drives of some phantom footage I have to do a more accurate test.
I took a 4 minute quicktime I had, already cut and graded, and transcoded that to uncompressed rgb. it was almost 40 gb, and I then transcoded that to pro res 4x4. obviously results will vary when there really is a full amount of color information in there, but I don't really expect it to be THAT different.
Results were pretty good, a 4 minute clip took 6:18 to encode. and there was plenty of movement and big landscape shots full of detail. Roughly 1.5x slower than real time. Shooting narrative I think this is perfectly doable. Encode directly from the SSD to your back up drive. than do you duplicate drive for backup. throw back ssd back into mix for them to format and shoot on. Depending on your shooting pace this maybe too slow though.
Little more accurate testing to come when i get my ram upgrade in and I pull some rgb footage. I'll also be testing compressor, and mpeg streamclip.
