Emanuel
Cross-Examiner
Today, I just saw Bergman's Saraband (CineAlta F900 shooted) digitally projected from a HDCAM tape and I can tell you that it was the worst CineAlta experience that I had, maybe because it wasn't Digital Cinema but only video. However, from the best Barco video projector that it was possible to get three years ago.
With noise and pixelization, very noticeable, except in the case of close-ups [in that case less for the noise but not as so good for close shots in terms of pixelization, sometimes, also there: it's the case of the Martha's glasses (Liv Ullmann's daughter)]. But depth, definitely, it wasn't the case! Concerning highlights blowing-out, my goodness! [I know that my basis is the film but the truth is that I have seen a lot of CineAlta stuff - even SD!...considering the interlaced videoish look (the film cleans!) - 35mm blowing-up with other results very different.]
That's why I am a 35mm film-out believer...
Well, I know, as Barry said:
1) But I ask: And what about an uncompressed HD workflow since the the shooting (mostly for who goes to uncompress@post production) through the analogue output comparatively DVCPRO-HD@P2? For better 35mm film-out purpose!
When you, Barry, are saying that «HD-SDI can take the direct digital stream right off the DSP» [2) first of all, what's this: DSP?...what is it its real importance?]
2B) Does it mean that with the uncompressed HD analogue output it will not be possible to have all the progressive and other advantages stuff like settings, Cinegamma, etc.?
That is: with uncompressed HD we will have less than DVCPRO-HD, in terms of quality, maybe not(?) but regarding film-look/cinematic properties?
3) «HD-SDI is superior to analog output» How far (is it)? Theoretically by guestimate? Because I prefer a progressive CCD rather an interlaced one.
It's open other threads in the technical & hardware sub-forums where the idea is the development of a solution for achieve this better level from a HVX for all that need it!
LINK to HD Converter (Encoder), Analog Component HD to HD-SDI
LINK to HD-SDI Flash-RAM Recorder
As always, wise and smart words.Barry_Green said:analog won't be exactly the same as HD-SDI of course. HD-SDI can take the direct digital stream right off the DSP, whereas with analog you have to convert that to analog, then capture and digitize that back to digital. HD-SDI will of course be cleaner.
However, the two signals won't be the same no matter what you do anyway. The Canon looks to have a couple of stops less latitude, the HVX has CineGamma, etc. I think the actual form of uncompressed will have less final impact on your image than the chips and DSP will have. HD-SDI is superior to analog output, but whether it's superior enough to make much of a difference is a question for side-by-side testing to determine. One thing we know is that the Canon outputs its HD-SDI as 8-bit quantizing carried within a 10-bit stream, so it's not like you're getting full 10-bit quality from it.
