Ultracontrast+Polarizer Test....
Policar
Carbonite Member
Thought you might be interested. High contrast scene, everything set to zero in the scene file. Standard gamma. Circular polarizer, ultra contrast +3.
Conclusions? Draw your own. Mine are that the ultracon is not that useful a filter, but does have a very minor effect. Obviously, polarizers rock but are hard to work with. The ultracontrast +5 probably works better than the +3 I used, but obviously it is not a "film look" filter. (Which I would argue is good; you can do diffusion in post.) Also, the ultracon is clear so the blue tint is the "controlled flare" effect with daylight.
And thats the same ultracontrast that costs 150 bucks? To think i even considered buying one... Doesnt seem to do as much(in terms of look, not dof) that a 35mm adaptor does. Even without depth of field coming into play, i still dig the look that 35mm adaptors give
IT bought you about a stop of dynamic range. thats significant. look at the ground, and how much more detial it captures with the polarizer and the "ultracon" present.
