Two inputs onscreen at once? Panasonic BT-LH1700W 17" Monitor
David Shawl
Hi,
I'm reading that this monitor has a split screen function, but it might just be a freeze frame of one source, so you can compare to your live source....
I would like to know if I can have two HPX170s connected via HD-SDI to this monitor and have both live signal on screen at the same time for a multi-cam shoot I have coming up. If not, does anyone know of a comparable monitor that does? Thanks for your help!
-Dave
It is a freez frame and a live one. You can connect 2 cameras on SDI 1 and SDI 2 and play
with the 1 and 2 switch, but you do not have the two pictures in the same time.
