grahamcopeland
I have a shoot coming up that will use two HVX200’s and a Sound Devices 722, hence the title. I would like to know if anyone has a method to sync the time code between all the devices. I know syncing the two HVX’s is no problem via Firewire, but I do not know of any way to sync the cameras to the sound recorder, or vice-versa. To my knowledge, the SD 722 syncs over a BNC cable like most cameras and recorders. The HVX as you well know syncs via 4 pin Firewire and that is where we have the issue. The SD 722 has a Firewire port but that port’s only function seems to be data transfer. Is there some kind of Firewire TC to BNC TC box that solves all problems? Or some brilliant work around someone has cooked up?
Any thoughts are greatly appreciated. Thanks in advance.
