Turning on widescreen...
ciencin
After a year of having my dvx I tried turning on 16:9 mode but wasnt sure how to do it... :-\
I went to Menu > camera setup > aspect conv > letter box mode but all it seemed to do was add the two black lines on top and bottom...
Is this correct? I thought there would be a physical button on the camera to do it like on a pd...
If it is the original DVX100 or the 100A, you cannot actually record 16:9, but on the 100B, there is squeeze mode which records a distorted image, but is then stretched out in your NLE to look normal and the end result is a 16:9 image. If you don't have the 100B, you can purchase an anamorphic lens adapter that distorts your image without the small amount of resolution lost.
