commanderspike
Carbonite Member
I just found something interesting, which maybe has a lot of potential... it could allow us to use the full 35mm equivalent focal length of our Canon FD lenses.
I backed my Canon FD 50mm F1.4 onto a macro lens - a thin glass plate that screwed onto the back of my el-cheapo 0.45x video lens wide converter.
I placed the combination (held together with my hand!) to the back of the GH1. At the correct distance - much closer to the sensor than the FD adapter allows, I appear to be getting the full 35mm image circle appear on the LCD.
The macro glass is either acting as an optical reducer, or allowing the GH1's sensor to pick up on the image from the lens a lot closer to the sensor, so that the image circle is reduced but can still be focussed.
I can focus to infinity.
Interestingly, moving the combination of macro glass and lens further out to where the FD adapter places the lens gives the lens stunning macro performance at F1.4... but is is then useless for infinity focus.
I hope someone with the right machining tools and know-how can pick up on this macro glass insert and make an FD adapter with it. All it needs is a good seal to the body, the right distance from the sensor and the right macro glass. There is no reduction in image quality or brightness either - just an expanded field of view.
