I recently tried to synchronize two DV100A's for a multi-camera shoot using the FREE RUN timecode instructions on page 50 of "The DVX Book". I also followed the instructions perfectly but could never get the cameras to start with the same timecode as set in the TC PRESET menu (00:00:00:00 or 01:00:00:00). I even found on page 46 of the manual "when the progressive mode has been set to 24P or 24P (ADV), set the frame value to 0 or to a multiple of 5. If any other value is set, the time code recorded will shift." I did that but with both methods when I went back I also found that the TC on the cameras had shifted back to different readings, not keeping the TC that I had set. Has anyone else had a problem with this?
Seconde question is: if I can get this to work, is it possible to do it with 6 or 8 cameras. My concern is will all the cameras be able to receive a signal from the remote control?
Thanks in advance
Thanks in advance
