Christian m
I know this kind of has been discussed before, but now sachtler and vinten have made a few changes to their lineups(and additions...).
Basicly I need a larger tripod system than I had for my old cam, the DV6Sb. Did take the system with me last weekend and tested it while on the ground waiting for the heli. At first glance the only big issue are the legs twist WAY to much to be of any use with telephoto. But the head could work as kind of "emergency" solution...if it had 100mm bowl.
Ofcouse it would be nice just to call the dealer and order a Sachtler Video 18 system(or a panther X15)...but then there was the question of money. Another point is the fact I bought the hpx500 primary for shooting the next 8months, with the option for reselling it or keeping and continue working with other projects. That mean that if i let go of the Dv6 system today i need the system i buy for the 500 to work fine with smaller cams as the hpx170.
The shooting conditons here in Norway rules out a lot of options, need to be able to use the tripod in cold winter, it was -30 celcius last winter when shooting. The DV6 head managed this with ease. Libec and Manfrotto are not an option and if the gear in use in Norway gives any direction it's that sachtler pretty much owns the market together with Vinten. But from vintens webpage i can't find that any of the vision 8-11 are rated for use in below zero?
Anyone used the DV12 with Hpx500? The 500 setup are canon kj16x77 lens, idx endura 10 battery and the odd shotgun mic, camera light and a light clamp-on Vocas MB.
At the moment I also consider buying a pair of 100mm sachtler legs, adapter and use the DV6SB head another month when I get to know a bit more regarding needing to be very run and gun with my gear or if a more ridgid system will be needed. I know the ENG crews of NRK(public broadcaster here in norway) use the DV8SB on 75mm cf legs for their Xdcam 2/3" setups which weighs in a lot more than my hpx.
